Old 06-01-2021, 10:26 PM   #92 (permalink)
EcoCivic
Well I "solved" the problem of the high/loping idle by pulling the ECU's speed signal pin out of the plug. That way my EPS system stays happy and my speedometer/odometer work, the ECU just doesn't know the car is moving. Initially the only thing I noticed is that my Scangauge no longer showed my MPG, but then I noticed that I no longer get good engine braking when coasting in gear. I looked at the fuel trim and it doesn't look like the ECU is going into decel fuel cut anymore. I guess it won't if it doesn't see that the car is moving. It seems like trying to get the auto ECU to work properly with this swap is a losing battle.
After reading a bit, it looks like a high idle while coasting is normal for some manual transmission cars. Hopefully that isn't the case with these Civics, I really don't like it when the engine revs way up for no reason and lopes when I'm rolling in neutral.
The Following User Says Thank You to EcoCivic For This Useful Post:
Ecky (06-01-2021)
