Old 06-02-2021, 12:05 PM   #117 (permalink)
aerohead
to suggest
I'm not in immediate possession of enough data on any particular vehicle. Would you care to suggest a modern one? One made in, let's say, the last 20 years, which is relatively common/popular?
I was hoping that a member or guest, with a larger database than my own, might step forward with a well-documented example.
In the meantime, I'll set up a gray matter sub-routine and see if I can isolate a candidate.
Hucho had the VW 1500 notchback, but that's going way back.
