Originally Posted by jakobnev
That was so annoying!
He never gets to explaining how the new connecting rod actually works!
Everything I can find basically says it's a big displacement 4, but designed with a flat plane crank and somehow significantly shorter con rods than you would normally see.
A guy, claiming to be the founder, repeatedly says the engine does NOT use freevalve technology here:
https://www.thehulltruth.com/boating...tboards-2.html
... but that it will be an option?
Anyway, if you want to see his posts, his username is afa928. Beware the annoying continuous scroll software on that forum though.
Sam
