Old 06-03-2021, 05:50 PM   #383 (permalink)
19bonestock88
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
Big update: the landlord pulled a dirty trick to evict me so I’ve been living off grid for a while, but I’ve been making progress all the same.
I finally fixed the broken front end from the bear hit, pulled out all the AC related stuff, redesigned the fender vents, fully ducted the lower grille opening to the radiator, and installed a front belly pan, going back to the oil sump.
Afterward, I started lightening my doors (rears first), removing a little metal from the inner skin where convenient and drilling lots of holes in the interior door panel and deleting the factory handle, replacing it with a pull rope
Lastly, I’ve installed a lightweight fixed back vintage racing seat on homemade mounts. No height adjustment and no sliders. I’m estimating it’s around 30lb less than the Recaro seat that was there
ID:	30765   Click image for larger version
ID:	30766   Click image for larger version
ID:	30767   Click image for larger version
ID:	30768   Click image for larger version
ID:	30771   Click image for larger version
ID:	30772   Click image for larger version
My current Ecotec project...
My last Ecotec project...
The Following User Says Thank You to 19bonestock88 For This Useful Post:
Ecky (06-03-2021)
