Old 06-04-2021, 01:46 PM   #10 (permalink)
aerohead
CANVAS : a really sick idea
This is for any member, guest, or lurker, who's had the misfortune of dead-heading with a Class-8 Tractor, pulling a flatbed semi-trailer.
You've delivered your load to the customer, you and your team driver have contacted dispatch or a logistics broker and can't find another load anywhere near your location.
Your facing a long OTR stretch, to pick up a load far away, dead-heading with one of the worst examples of modern-day truck aerodynamics!
Not a problem!
Secured to the trailer's forward bulkhead is another 'tarp.' however, this one has a 'trick.'
It's actually an inflatable, streamlined envelope, designed specifically for this contingency.
It holds all the unused, rolled or folded cargo tarps, plus inflates into a perfectly streamlined half-teardrop, which 'disappears' to nothing, by the end of the flatbed. Powered by the charging system of the tractor. Another 'glad-hand'.
Secured with tie-downs, periodically, along the length of the trailer, you've converted one of the highest-drag 18-wheelers on the road, to the lowest.
In a few minutes.
With an inflatable gap-filler on the forward face of the same bulkhead, you knock off another 19% drag ( NASA ).
The upper body is now completely streamlined.
Another inflatable fairing, under the trailer, behind the rear wheels/ DOT bumper region, trims drag even lower with an underbody 'Kamm-back.
Then Heaven forbid, you use the five (5) feet, allowed by federal law, to inflate a final underbody boat-tail, outside, beyond the DOT bumper, creating the lowest-drag, 'air-bagged', Class-8 vehicle on Earth. And the fuel economy and range to prove it.
Trailers are already wired. One larger conductor, to handle the increased current demand of the small blowers aren't rocket science.
Any cargo load capacity loss of an 80,000-lb GVWR vehicle, due to the added weight of an 'air-bag' system wouldn't even register on the economic radar.
Simple software and Blue-tooth connectivity could easily 'automate' some of these features. Drivers wouldn't be out any extra effort.
These are the 'Lost Dutchman's Mine' of real wealth. It's very strange to live in a capitalist society which allows profit potential like this to languish and lie dormant for 86-year on. Especially in times of anxiety over electrification of transport and range issues.
Aerodynamics is great for everything except when wheels are involved.
PS 'steal this invention!'
