Old 06-08-2021, 02:09 PM   #60 (permalink)
Vekke
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
I am back in finland and the deflector testing has continued in my ID3.
This shape has worked best in the Id3. I have tried today. 2 versions of the flat plate, which I had previously, and no flaps at all. The straigth flap is still behind this curved flap. At the moment car is lowered 30mm by H&R springs. In front lowest point of that deflector is now in 80mm ground clearance. This hard 2mm abs is only for testing more flexible solution will be needed in the end.
Same/similar curved deflector at rear (can be seen at the pic) which was 20mm shorter did not work at the rear and the oem one worked better. Will test other version front and backif I will find ever better solution.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following 3 Users Say Thank You to Vekke For This Useful Post:
California98Civic (06-08-2021), freebeard (06-08-2021), woodstock74 (06-08-2021)
