Measure the pressure drop of the whole intake, and measure just the pressure drop of the filter. What you'll find is that your filter is very likely the smallest restriction in your intake. Do it at various rpm and you'll probably find the filter accounts for less than 2 inch of water below 4000 rpm.
The
eleminating negative boost articles at autospeed are a good read.
