Old 06-10-2021, 04:24 AM   #56 (permalink)
JulianEdgar
Originally Posted by Vekke View Post
Test method is still same. Average measured from start to A B directions. Results are in same order of magnitude already at the middle of test leg. If you calculate results from 4th measuring point you would get up 17.68kWh vs 18,3 kWh and thats 3,4% difference.
Ok, you obviously didn't understand my points last time.
The data is valueless - you have (off hand) something like a 16 per cent variation in instantaneous measurements in ostensibly the same configuration - and you're trying to calculate 3 per cent changes.
It's really easy to do crap measurements fast.
What actually is your reasoning for not doing (say) 20km average energy consumptions at 100 km/h, one each way?
