Custom Rywire Harness for 88-91 Civic/CRX with D15Z1 - $1000
Hello,
I have a custom-made Rywire Harness for an 88-91 Civic/CRX running a D15Z1 (Civic VX) engine.
It's made to run from the engine to a P07 ECU code free (OBDI).
This harness accommodates both EGR sensors (manifold & vacuum box).
Included is a separate jumper harness, so you can use a wide or narrow band O2 sensor (4 pin to 5 wire O2 ntk sensor adapter).
This harness is brand new and never used. I have the original receipt as well.
I bought this 7 years ago for a project that never came into fruition.
I'm located in the San Francisco Bay Area.
I'll try to post some pics in the following days.
Thank you for reading.
