Old 06-14-2021, 10:39 PM   #64 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
I'm most curious to keep track of your long-term reliability. Everything else on paper looks perfect.
I'll certainly let you know of any problems. There has been a couple glitches. One the rear hatch is supposed to time out when left open but it seems to do it after only about a minute of leaving it open. Then it wont close with power, has to be closed by hand. Supposedly that's the design but I could see after 20-30 min not 1 min. The other thing it has done about 6 times is just throw the check eng light and parking brake light on startup and then not allow to go into drive or reverse. Just turn it off and back on and everything's fine. I don't know what that is but common on the forums. Seems not going super quick from unplugging, to starting, to gear, keeps it from happening. I sometimes do all those things in less than 30 seconds when going to work. Also my driving history on the uconnect wasn't updating for the last 3 weeks but just started again yesterday. All of this stuff seems like programming bugs so hopefully they can all be over the air fixes which the uconnect system allows. So far none have been available.
