It depends on how fast you want to drive.
On the highway the battery does not get exercised much so its condition would not make a difference. Speed is everything for MPG; the slower the better.
An old Civic with a manual gearbox could well beat the Prius. The more you mod, the bigger the difference; the Prius is already quite optimal and relatively heavy, your options are limited there.
I would still go with the Prius because it is a lot safer and easier to drive.
![](https://images.spritmonitor.de/544051_25.png) lifetime FE over 0.2 Gigameter or 0.13 Megamile.
![](https://ecomodder.com/forum/fe-graphs/sig7127a.png)
