Old 06-15-2021, 01:41 PM   #6 (permalink)
redpoint5
90 day: 38.47 mpg (US)
Originally Posted by Isaac Zachary View Post
And yet another problem is oil consumption. I do thoroughly believe that if the oil were changed at least every 6 months or 5,000 miles these engines would last over half a million miles. But people go by the yearly oil change and then end up with oil consumption problems down the line, which in turn kills the catalytic converter.
I don't know how much of a unique problem this is with Prius, but I doubt oil change interval has much to do with it. I've checked my oil condition with yearly changes and it was still well within spec.
The unique thing about the Prius is that it's designed to run the engine at high load continuously, which puts more strain on everything. If excessive wear is a problem with the Prius, I would suspect the cause is high loads and thin oil (0w20).
