Old 06-15-2021, 06:34 PM   #46 (permalink)
serialk11r
Stock intake VANOS looks completely fine to me. You may consider retarding the first 5-7 columns a little bit to stabilize lean burn. I would set the first column to 120 down to 3500rpm and then gradually drop it to 112.5.
Exhaust I think you have the right idea, though I don't understand that little 100.12 island. I would keep the last 3-4 columns stock, and basically shrink that blue/purple island towards the right since you don't need the exhaust dilution to reduce your pumping losses anymore. At medium load, a little bit of overlap is helpful for raising charge temperature and combustion speed. E.g. at 2500rpm, I would set that row to something like 105 105 105 102 100 97 94 92 90 90 92 95.
The Following User Says Thank You to serialk11r For This Useful Post:
Juho (06-16-2021)
