Old 06-16-2021, 01:42 PM   #17 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
About block heaters. The stock block heater only helps a little. I'm going to change mine out (both cars) for circulating tank heaters that are at least 1,000W. I'll probably go for 2,000W heaters though since I have a 20A outlet. I've used that's kinds of heaters on other small cars with excelente results. I also might use a 1,500W block heater and a 500W heater of some sort to heat the traction battery.
