Thanks for the advice, I'll try that and let you know how it works.
The 100.12 island is actually small accident, when I tried 105->100 (turns into 100.12)->90.
Earlier tried even 82,5 , but it was clearly worse in every section expect around 4000rpm at more than half throttle went lean and caused small missfiring -> something changed because needed more fuel.
