Old 06-17-2021, 06:58 PM   #27 (permalink)
cRiPpLe_rOoStEr
I think another problem with turbo engines is they tend to lower the compression ratio. My guess is the motor with more displacement had a higher compression ratio than the ecoboost.
Even though direct injection is supposed to allow for a higher compression ratio with fewer risk of knocks, whenever there is turbocharging in a gasser even the ones with direct injection get a lower compression ratio. But anyway, due to the naturally colder intake temperatures at an aspirated engine with port injection, it still seems better suited to heavier duty.
redpoint5 (06-17-2021)
