Old 06-18-2021, 03:09 PM   #8 (permalink)
aerohead
hearing
Originally Posted by ilayda View Post
I'm hearing splashing in my dashboard like heater core is clogged but it is not. Just wondering if I can burp the air out, will it heat up faster in the morning?
smmgoal.com
1) could it be the blower striking water in the fan housing, caused by a blocked condensate drain during air conditioner use?
2) I experienced this with a friend's package window air conditioner unit.
3) the buyer was required to drill out a factory located drain hole, which they failed to do.
4) If you have high humidity and flying insects that like to build nests inside machinery, it could explain what's happening.
