Old 06-20-2021, 01:47 AM   #53 (permalink)
serialk11r
Good luck with speeduino, does it let you use wideband O2 output to get whatever closed loop lambda you want? That would make your tuning much easier, just back off a little exhaust cam retard from stock, and then just jack up the lambda and timing until it is unhappy.
