Old 06-20-2021, 04:15 AM   #134 (permalink)
JulianEdgar
Originally Posted by Vekke View Post
I count only the end results when calculating anything.
Good!
On longer test runs if car is not performing any better than previous best the test can be aborted after 2 bad measurin point results.
I don't understand - if it doesn't match what you want, you abort the run?!
To avoid just that bias I never analyse the results until all the data is in. Otherwise, much too easy to introduce your own bias.
If the run would be more longer like +1 km it would bring more accuracy, but then again we are already at the limits of the accuracy of the dash 0,1 units so extra accuracy would be wasted in my eye.
You're confusing 'resolution' and 'accuracy'.
