Old 06-23-2021, 08:56 AM   #318 (permalink)
serialk11r
Originally Posted by funkhoss View Post
Basically, whenever I'm driving, the engine is in one of two states. Either the engine is running, in closed loop (to avoid power enrichment) with the MAP at 90-100 kPa ("wide open"), or it's off. Whatever it takes to keep the engine in one of those two states...that's what I do.
Have you retuned the ECU to get closed loop immediately when it's turned on? I think 5 seconds is the typical closed loop delay on a warm engine. I have my car set to 3 seconds down from 5 stock at 200F coolant temp, and 5 seconds at 180F coolant temp down from 8, and my open loop map is leaned out a little.
