Originally Posted by aerohead
This area may denote the 'bistable' flow Hucho attributed to angles within the 28-degree-to 32-degree range, where the separation line jumps between a fastback and squareback wake pattern.
Something perhaps which showed up in an anechoic / accoustic wind tunnel as 'booming.'
The rear hatch angle is nowhere in the range you have described.
