Old 06-23-2021, 05:55 PM   #586 (permalink)
JulianEdgar
Originally Posted by tomi_k View Post
Planning to use plywood to make form on top of a wooden frame... just to give rough shape... details will be made with foam.
Any recommendation for a plywood thickness which would be easy to "bend" and form.....1/4" thick?
Stiffness depends on the grade of plywood, so best to go handle a few sheets. Around here at least, 6mm (1/4 inch) ply may well be too stiff if you want to try to bend it at all three-dimensionally.
tomi_k (06-23-2021)
