Old 06-24-2021, 10:01 AM   #8 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
We're talking about the MR2 Spider?
My suggestion is to research and first see if anyone has done an AWD conversion before and then go with that. If not, you're going to be the first to do both the front drive line and EV aspect at the same time.
I know with the classic VW Beetles some had done 4WD conversions before. Using the same parts with the exception of modifying the transaxle adding the drive shaft, all you'd need more would be the electric motor connected to the new front differential and batteries and controller.
