Ecomodder.com version (original car in pic is about 1 1/2" too low).
I would like to change the final and 5th gears -especially after reading MetroMPG's tranny change- which would change 5th rpm from 3000 @60 mph to 2242 @ 60 mph! 34% lower for 5th and about 20% for the other gears.
The K20a3 motor is fairly torquey for a Honda lump and can be tweaked quite a bit. It's amazing how versatile the K series is because almost all the parts from all the motors/trannies can be swapped around.
