Old 06-24-2021, 10:27 PM   #154 (permalink)
cRiPpLe_rOoStEr
Plexiglass is a trademarked name of Dupont.
Didn't it become some sort of genericized trademark?
I believe you are describing acrylic sheet which comes in many subsets of density, toughness and flexibility.
You're right. I was refering to acrylic sheets. And some clearly have a poor optical performance which renders them less desirable than actual glass, while others are OK for that matter.
Lexan is another trademarked polycarbonate with many coatings applied to alleviate the inherent faults of the base product for a specific purpose.
I remember Lexan sheets being used more often on racing cars for weight savings.
Home building places stock a common house window glazing grade that tends to not see rock impacts
Common house window glazing in my country is not so easily found on such grade.
