Old 06-25-2021, 04:09 PM   #1 (permalink)
EcoCivic
Electric AC compressor?
Hello everyone, I am wondering if anyone here has ever somehow used an electric AC compressor in a vehicle or has any ideas on how to do so. I like being cool but running the AC really kills my MPG, so I am wondering how practical an electric AC compressor would be so I could stay cool without killing my MPG. The other really nice benefit of an electric AC compressor is that I could run the AC while parked without running the engine so I could be comfortable while sitting in my car eating and such.
Obviously for this idea to be beneficial, the electricity to run the compressor would need to come from a source other than the alternator. I'm thinking a gen 4 Prius battery would be a good power source due to its 8.8 Kwh capacity, relatively small size and weight, and relatively low cost at a junkyard. If an electric compressor draws 2Kw I should be able to run my AC for 4 ish hours off of a charge, which is way more than enough for me.
Initially I was thinking of using the Prius compressor since those are available used for pretty cheap, but after a bit more research it looks that may not be possible since it appears to be a 3 phase inverter driven AC motor and the inverter seems to need a signal from the climate control module to function.
After seeing how expensive DC powered AC compressors are, I'm starting to think a better option may be to utilize the OEM compressor by using a belt drive and an electric motor to spin it. This method would also have the advantage of not requiring custom AC lines as long as I could find a motor small enough to drive the compressor in its current location, perhaps something that could fit where the power steering pump used to be. I would just need to figure out a way to power the compressor from the battery pack.
Although this setup would no doubt be complicated and pretty expensive, it also has some very real benefits and I think it should be doable.
If anyone has input, ideas, or suggestions, please feel free to share them. I appreciate any input.
Thank you very much in advance, looking forward to hearing your thoughts on this concept!
