Old 06-26-2021, 01:13 AM   #17 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Maybe install a switch on the accelerator that turns on the A/C clutch whenever you take your foot of the pedal.
Maybe: Aluminum foil reflective roof.
Maybe: Water pump and cooling loops in driver's seat that go to a heat exchanger right after the evaporator so you get more of the cooling effect on your body directly.
