Originally Posted by Isaac Zachary
The problem is finding a small water cooled engine that provides enough power. Of course if you drive down the Autobahn you'll need more power to keep your speed up.
I think I figured out that a proper voltage reconfigured genset of 6hp was enough wattage capacity to drive my Ranger at street speeds up to 40mph. A dual cylinder 25 hp genset should do enough watts to drive pretty much everything else modern
