Old 06-26-2021, 04:31 PM   #38 (permalink)
Taylor95
Jeep - '97 Jeep Cherokee Sport
90 day: 19.36 mpg (US)
Blueberry - '07 Toyota Camry SE
I was thinking about a van initially too but I wasn't too sure about which ones to look up.
There is one more thing I would like to mention: we will be getting a Rav4 Prime (if we can find one) in the near future. That has a tow rating of 2500 lbs. If We can find a trailer light enough, the Rav4 would definitely be very economical, especially because I might be able to tow with the electric only driving capability.
Does anyone know how tow ratings are determined? Are there any negatives to towing above the capacity by a few hundred pounds? I assume that the Rav4 Prime would be limited in the areas of suspension and perhaps the frame. I would think that there is plenty of pulling and braking power to tow well above 2500 lbs.
Edit: Supposedly the only relevant difference between the Rav4 Prime and the Rav4 TRD Adventure (tow capacity of 3500 lbs) is that the latter has a transmission cooler. Would simply adding a transmission cooler be sufficient to tow a little more?
