Originally Posted by cRiPpLe_rOoStEr
Reducing heat intrusion is a good point. On a sidenote, considering some motorcoaches are now fitted with an air-cycling setup more similar to what is found on modern airliners instead of the vapour-cycling more commonly fitted to cars, that's something I would be quite tempted to try.
Air cycling? That sounds like it would be extremely loud in a car!
I think the OP has done pretty much everything reasonable to reduce heat intrusion. Cars just get hot and you gotta run the A/C I guess.
