Old 06-27-2021, 04:25 PM   #29 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
Just running your a/c is the least expensive solution by a factor of 100 I bet. What exactly do you mean kills your MPG? Going from say 40 to 35 isn't that big of a deal. Maybe $100-$200 a year. However you charge the battery will take some energy too. If you really want to get 40+ and run your A/C just buy a used Prius for probably less than any wierd conversion would cost. Plus I bet adding 300 pounds of battery might also hurt your MPG similar to running the A/C on the belt.
The Following User Says Thank You to Hersbird For This Useful Post:
EcoCivic (06-27-2021)
