Old 06-30-2021, 11:01 AM   #333 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Turn the bloody circuit off at the breaker and look at the wire gauge installed in the outlet box. If it is 10 ga, you're good to 20 amps. (It will be marked for the gauge inept). Probably has a 20 amp breaker in the box to start with if the house was built in the last 30 years. Most garages are on their own circuit unless the builder was VERY cheap. I have a 20 amp circuit just for the garage opener in a 70 year old house & it's only a 15 circuit box.
But how many are 20amp 240V? Usually there's a 15 or 20amp 120V outlet.
You could wire the white (normally neutral) wire to a double throw 20 amp circuit breaker (if thick enough) as long as your EVSE doesn't have or use the neutral pin. But that would hardly be legal.
