Old 07-02-2021, 01:14 PM   #89 (permalink)
aerohead
direction
Originally Posted by jakobnev View Post
The plank will move half speed in the same direction as the car.
The upper wheels turn half as fast as the bottom wheels.
1) since there were no arrows provided in the illustration, I did a napkin sketch.
2) the car is moving from left to right.
3) the wheels in ground contact are rotating clockwise.
4) the upper wheels are powered by their contact with the reduced-radius axle of the ground contact wheels.
5) as the lower wheels rotate clockwise, as in meshed gears, the upper wheel spins counterclockwise.
6) a plank, resting on the upper wheels will be pushed off the cart, falling behind it.
That, or the Kool-Aid's been real good!
