Old 07-02-2021, 04:14 PM   #93 (permalink)
RedDevil
90 day: 57.12 mpg (US)
Oh boy. Bear with me. Deep dive!!!!
1) the little model is not air driven.
Air driven? You miss the essential part.
it has absolutely NOTHING to do with the speed of the air!
The only thing that matters is the difference between the wind and ground speed.
It should work on a treadmill in still air just the same as with wind on solid ground, or salt, or whatever.
2) the little model does not mimic El Mirage Dry Lake conditions
The only thing that matters is a difference between wind and ground speed.
3) it's Rick Cavallero who says in the vodeo that it's the body of Blackbird which is reacting to the wind impulse to move it ( disregarding the propeller thrust )
The air resistance of the body is negligible in comparison to the pressure on the propeller. When the car is not at speed the wind pushes against the body (which does give way by rolling away) and the propeller blades (which start to turn against the wind, so they give way less quickly)
4) we know from Hoerner that, Blackbird's drag will be over 3X higher with the wind from behind, than from the front, so it is a 'square-rigger sail' so to speak.
Bear in mind that the drag on the propeller has a diffeerent dynamic than the drag on the rest of the car, because it is virtually moving slower (by slowly turning against the wind) and because its surface is much bigger.
5) the Second Law of Thermodynamics is operating at:
* wind-to-body aerodynamic coupling surface friction
* flow separation induced turbulence viscous shearing forces.
* dirt ground-to-tire tread interface
* internal hysteresis loss and heating within the tires
* all wheel bearings
* all gears
* all sprockets
* all power transfers from component to component
* all other bearings
* within every chain link swivel
* at the propeller-to-atmosphere coupling heating
( if you had the proper infrared imaging equipment, you'd see Blackbird raising the temperature of the air around it at all contact points, and within all it mechanical components ) That's all 'entropy'
The second law of thermodynamics is not what you think it is, I fear:
The first law of thermodynamics provides the definition of the internal energy of a thermodynamic system, and expresses the law of conservation of energy.[5][6] The second law is concerned with the direction of natural processes.[7] It asserts that a natural process runs only in one sense, and is not reversible. For example, when a path for conduction and radiation is made available, heat always flows spontaneously from a hotter to a colder body. Such phenomena are accounted for in terms of entropy.[8][9] If an isolated system is held initially in internal thermodynamic equilibrium by internal partitioning impermeable walls, and then some operation makes the walls more permeable, then the system spontaneously evolves to reach a final new internal thermodynamic equilibrium, and its total entropy, S, increases.
In other words, the second law describes entropy in an isolated system. Here we have two entities that move relative to one another; these provide energy to the system, so it is far removed from an isolated system.
6) the tires resist rolling on the dirt as a function of their coefficient of rolling force ( which must be quantified for dirt )
The only thing the ground needs to do is provide enough grip for the wheels to roll and be flat enough to not cause too much friction. Be it dirt, salt, ice, whatever. Tarmac and salt should do fine.
7) along with the body, the air flow impacts the thrusting face of the propeller.
It has to, otherwise it could not push the wheels over whatever they are resting on.
8) I'm uncertain how you could quantify what the forces would be on the propeller and wheels.
What about 'equal'? The wheels touch the ground, the propeller faces the wind; there are no other points on the car that endure outside forces.
9) the distance the wheels travel will be whatever it is.
10) the distance the slipstream moves through the propeller disc will be a function of its diameter and nominal pitch, along its axis of rotation as if it were moving along a helix of slope equal to it's blade angle. Which would need to well exceed the ground velocity in order for Blackbird to exceed the local wind velocity at the prop.
Ground velocity? OK, we're looking at the car now.
The prop does NOT push the air back faster than the ground moves.
It needs to move the air back SLOWER than the ground, otherwise the wind cannot push it forward as then it would require more energy to turn the prop than the wheels provide.
Because it is moving slower than the ground, it requires less energy to produce the same force the wheels get over a bigger distance.
11) we don't want to confuse gross available energy with net useful energy. Blackbird lives on the margin.
In a 1/2 ratio you can lose half the energy to all kinds of friction and still move at wind speed. That's enough margin for me.
12) do you have the propeller specifications for Blackbird?
Not relevant Any decent prop will do. Blackbird's officially goes 2.8 times the wind speed; there's enough margin whatsoever.
13) do you have the aerodynamic 'push' data for blackbird?
Again not relevant but it is directly opposed and equal to the force on the wheels. Pick a reasonable force to work with and do the math from there.
14) yes, when airspeed and ground speed are equal, there is no more impulse, and momentum is constant.
Indeed it does nothing when the wind does not blow and the ground does not move.
15) if the car is exceeding the windspeed, it has a negative impulse acting on it, it's running away from its energy source, while for the first time, experiencing positive aerodynamic drag.
But the main aerodynamic forces don't apply to the car, but the propeller (which is turning backwards slower than the ground speed so still moving forward related to the ground, and still enduring pressure from the wind.
16) impulse from the rear was experienced from a 'tailwind' up until the point where air velocity nulls, at zero apparent air velocity, measured only at the car.
You forget about the propeller turning backwards, which is needed to maintain pressure to move the car forward.
17) if the ground speed of the car exceeds wind speed, its now in a headwind, while the ground is always experiencing some true wind.
The ground endures the wind at full speed, the propeller at maybe half speed, the car faces a headwind.
18) the car is in an ocean of moving air, like a commercial airliner in the Jet Stream, going supersonic by ground measurement, however, only 600-mph by pitot tube/ manometer aboard the plane ).
Replace car with propeller and then you've nailed it!
19) the ground just experiences, from a fixed position, whatever the wind is doing.
Yes, the wind and the ground are the two main entities and they move relative to one another.
20) there would be a point where the propeller experienced zero wind speed, however we'd need to know everything about the prop. to calculate that.
No! Then it does not work.
If the propeller endures zero wind speed there is no pressure on the propeller, no force to drive the car forwards, to push the wheels over the ground and to turn the propeller. It would come to a halt.
The propeller needs to move the air passing through at a speed just shy of the speed of the car. Then the wind can still put pressure on it, forcing the car forwards.
21) the wind will just blow.
Yes, the wind and ground form a dynamic duo moving relative to each other.
22) if the propeller is turning, and it has a certain degree of slipstream coming off it, it will be acted upon by the wind, even if exceeding the wind speed.
There's a margin to compensate for any bad effect from that (apparently).
23 ) I'd prefer we use 'power' rather than energy.
Fair enough, will do.
24) Blackbird will have a ROAD LOAD Horsepower requirement under any given set of circumstances.
Road load horsepower definition
The amount of power at the driving wheels needed to move a vehicle down the road at a steady speed . This power varies according to the vehicle's speed, aerodynamic drag, mechanical friction, and the tires' rolling resistance . Road-load horsepower is distinct from engine power because the output of the engine is sapped by various mechanical losses between the engine's output at its flywheel and the driving wheels.
Assuming friction on the wheels, gears and car body is relatively low compared to the load on the propeller, there is very little power needed to move the car other than overcoming the resistance from the propeller being driven against the wind.
25) this power is associated only with aerodynamic drag and rolling resistance.
Not so much just drag but load on the blades of the propeller, and not so much friction as the force that friction provides to the wheels to make them turn.
26) if the propeller can impart horsepower to the atmosphere in excess of the road load, it will continue to accelerate. That's neve been in question.
It obviously cannot provide more power to the propeller than the wheels provide. But then it does not need to, as it pushes the air backwards at a slower speed than the car is moving relative to the ground.
Power is force times distance, and the propeller endures the same force over a smaller distance.
27) everyone ( I believe ) accepts that the propeller is 'tacking' around its shaft and capable of imparting thrust.
28) given a true wind speed spectra, a terminal ground velocity at that specific wind velocity, and all the necessary particulars of Blackbird, things will be what they are. I'm happy just to have the facts, without all the drama.
And it's the shortcomings of the video presentation which appears to have created all the controversy.
The treadmill tests proved nothing.
The test at El Mirage is lacking in information.
The $10,000 bet means nothing to me.
I'm just asking for algebra. I want the left side of the = sign to match the right side.
I too see a shortcoming, but not in the video.
Funny how easy it is to spot the shortcomings in others and how hard it is to see your own. A man cannot look beyond his own horizon, but easily see what behind the horizon of others.
aerohead (07-02-2021)
