Old 07-02-2021, 08:03 PM   #38 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
That was my point, that tire choice makes more difference than anything else. If someone is complaining about handling in a Prius, they should ditch the stock tires and wheels. They should also ditch the idea that they are going to race around in a Prius.
Even with sticker tires the 2nd Gen Prius still handles poorly. Soft springs, budget suspension, no feel to the steering, and lots of body roll.
The problem I found with my 2nd gen Prius was the lack of spring options. Anything stiffer than stock was also shorter. I don't want a low-rider Prius, it scrapes enough speed bumps at stock height. Want stiffer struts or shocks? Sorry, those will be custom.
Which is fine - most people don't care but handling is a safety issue to me. I've actually had to do something similar to the "moose test" with a car before to dodge a car that pulled out directly in front of me when I was going 60 mph.
When it comes time to change out suspension components I want the option to improve on the stock parts.
The Following 3 Users Say Thank You to JSH For This Useful Post:
Ecky (07-02-2021), JacobLeSann (07-02-2021), redpoint5 (07-02-2021)
