Old 07-03-2021, 03:54 PM   #103 (permalink)
RedDevil
90 day: 57.12 mpg (US)
I feel confident enough in understanding how it works that I can do predictions of what happens if you change things.
If you'd run the Blackbird backwards it would still run downwind faster than the wind.
Likewise, if you put the model backwards on the treadmill it would still run faster than the tread.
If you change the gearing on Blackbird so that the propeller moves air faster than the wheels run over the ground (instead of slower), then it would run straight against the wind instead of with it. It would do so even backwards.
