Old 07-06-2021, 11:00 PM   #13 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Originally Posted by samwichse View Post
I mean the basic friction equation is:
friction force = (coefficient of friction)*(normal force)
Static and kinetic friction are the same equation with different values for the coefficient of friction.
So yeah, downforce (adding to the normal force) should pretty linearly increase traction.
Mmm.... Interesting.
But if you take a car and just add more weight over the front wheels the car will tend to understeer more (inertia overpowers traction). And if you do the opposite, add more weight over the rear wheels it tends to oversteer (again the increased inertia is more than the increased traction.)
So maybe it's linear, but at a lower increase than inertia.
The Following User Says Thank You to Isaac Zachary For This Useful Post:
AeroMcAeroFace (07-07-2021)
