Old 07-07-2021, 03:31 AM   #17 (permalink)
SDMCF
I still remember when converting from gasoline to dedicated-ethanol was usual in Brazil when a naturally-aspirated engine got an aftermarket turbocharging setup, as it was much easier to mitigate knock. Cold start could become quite a PITA. Now that direct injection is more widespread in engines turbocharged from the factory, it's not much of an issue as it used to be.
That is interesting. A few years ago cold start on E85 could be a problem here - although typically cold start here would be a lot colder that in Brazil. I hadn't thought about it until you mentioned it but I haven't seen anyone having that problem for quite a while, with any injection type. Perhaps the tuners have just got better at it.
