Old 07-07-2021, 04:16 PM   #18 (permalink)
cRiPpLe_rOoStEr
Originally Posted by SDMCF View Post
A few years ago cold start on E85 could be a problem here - although typically cold start here would be a lot colder that in Brazil. I hadn't thought about it until you mentioned it but I haven't seen anyone having that problem for quite a while, with any injection type. Perhaps the tuners have just got better at it.
Presumably the sequential injections becoming more common than continuous ones also improved the thermal management, leading to a shorter cold phase. In Brazil it has been increasingly common for flexfuel cars with port injection to feature electrically heated injectors as a starting aid with ethanol, while older ones resorted to an auxiliary gasoline tank which also used to be common back in the day of the dedicated-ethanol cars.
