Old 07-10-2021, 06:57 PM   #7344 (permalink)
jedsmd
PLUGnGO
jedsmd's Avatar
"bat-amps-lim"
Hi All
I have one of Paul's IGBT DC controllers (stinky diaper?).
I am trying to limit battery current to protect a new set of batteries.
The controller config file currently has "bat-amps-lim" set to 0000. I assume the zero value means battery amps are not limited.
My desired value is a max of 400 amps. If I set bat-amps-lim to 0400, the controller stops working. I think it is limiting battery amps to zero or a very low value.
Does anyone know if "bat-amps.lim" works? Am I not setting or using it correctly?
Thanks
