Old 07-12-2021, 07:42 AM   #7 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
First, there is a HUGE!! range in rolling resistance between make and models of tires within a given tire size. So large that changing tire sizes is small potatoes. In this case, the change would be less than 2% (in RR)
Now the LT215/85R16 is slightly larger in diameter, and that may result in slightly better fuel economy, but again, small.
I don't think you'll be able to measure a difference - and what difference you might be able to measure might be the difference in the amount of tread rubber. Worn tires get better fuel economy than new ones.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
