Old 07-13-2021, 11:27 AM   #47 (permalink)
EcoCivic
Not long ago, I swapped the crank pulley on my 2.4L engine for the pulley from the 2.0 Type R engine. I believe it was ~11% smaller in diameter.
I imagine you probably have an OEM option.
Thank you. The K series crank pulley won't work, I have a K24A2 TSX engine siting in my living room and already checked.
The problem is that the D17 engines don't have aftermarket support like the K series and OEM parts aren't generally interchangeable like with the D16's, crank pulleys included. However, I have heard that the B series crank pulleys will fit, but I would have to look into that.
