Old 07-15-2021, 02:37 AM   #4 (permalink)
oil pan 4
Aha, bahaahahahh,hahaha hahaha.
The government has demonstrated catastrophic lack of understanding to obd2 tuning.
I can drop the ecm out of my firebird in about 15 minutes with out any practice, pry the hot eprom chip out, insert an OEM tune eprom, then in 5 minutes move the distributor base advance to the BS 8 degree setting with a timing light.
After smog is passed put the hot eprom back in and crank the base timing back up to about 20 degrees by eyeballing it. It's good for about 2 to 3 mpg and at least 25 more hp.
Ecky (07-23-2021)
