Old 07-15-2021, 08:26 PM   #387 (permalink)
redpoint5
90 day: 29.78 mpg (US)
Originally Posted by Bicycle Bob View Post
Does the bike not have a kick starter? If not, a bump start is more fun anyway. You can delete the weight of the starter motor.
It's a 400 lb street bike, so no kick start. In my (original) CBR600, I replaced the battery with 6s 400F capacitors and had no issues except for the 1 time I let a friend ride it, and he drained them by turning the engine off but keeping the headlight on. I was barely able to bump start going down a steep and long hill. Pretty sure you need some remaining voltage to get the bump start method to work.
Originally Posted by serialk11r View Post
That's pretty weird, bikes are usually easy to start with a 7Ah battery. You can start most 4 cylinder cars with a 10Ah lead acid battery that's fully charged. Why not buy a 7-10Ah battery and see if it works first?
I bought a super cheap LiFePO4 battery and attempted to start the bike, but integrated into the BMS is overcurrent protection. It seems all of these cheap batteries contain this circuitry. I was hoping to find something with no circuitry, but no such luck... which is why buying the individual 7.2 Ah cells seems the best option at the moment.
... decided $31 to experiment is not too much. Placed the order, except it says shipping could take from 2-6 weeks. We'll see if the DMV can complete the title and registration on the motorcycle, or if I can build this LiFePO4 pack first. Not sure if I'll need to balance the cells... I've had a 20Ah LiFePO4 in a Prius since 2016 and never balanced it.
... in the meantime I'll get my supercaps going again in the motorcycle.
