Thread: Prius 75-91mpg
Old 07-21-2021, 06:22 PM   #220 (permalink)
Nathan jones
Ecomodding Apprentice
Some aluminium 6061 m10's, I will make aluminium plates for the composite doors, alu will hold lighter doors, maybe even the ones I have now but will wait...
I don't understand why Jaguar and others sing about alu panels, oxide always wins on paint when woven roving is so cheap
Some epoxy stayed green so it went in the oven. Wanted the grp seat also white to match the car, chose white because I took the aircon out
My friend will weld a new seatbelt anchor, I like the pretensioner to stay. The seat airbag will also be affixed
The calculator says next years new 0-60 will only be 6.1, I was hoping for under 6. Along with higher mpg...
Data is always in a safe zone so in real life it may be 5.8 or so
ID:	31053   Click image for larger version
ID:	31054   Click image for larger version
ID:	31055   Click image for larger version
ID:	31056   Click image for larger version
The Following User Says Thank You to Nathan jones For This Useful Post:
Ecky (07-28-2021)
