Originally Posted by JSH
Oregon has a similar law about removing old wood stoves and inserts when a house is sold. However, they can be replaced with new CARB certified stoves or insert.
This link from the Missoula County, Montana says you can install EPA approved wood stoves with PM emissions of 1 gram per hour or less.
https://www.missoulacounty.us/govern...-installations
Those would be pellet stoves. I guess "wood" but not cut/split log. I said you had to remove inserts, but that again means cut/split log burning, not gas or pellet.
I would love a rocket mass heater, and I did build a semi portable one for a squatters shack out innthe woods, but again, that wouldn't be EPA certified for use in the city.
It is just a city thing, go outside innthe county something like 5 or 10 miles and lots have wood stoves.
