Thread: Thank you
Old 07-25-2021, 08:09 PM   #54 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by Isaac Zachary View Post
Now it sounds like you're saying boat-tailing only works if you have it built at an optimal angle... As if a sub-optimal angle wouldn't help. After all, the template is rubbish, so following it should either not help or just make aerodynamics worse.
Is that what you mean?
Are you satisfied with sub-optimal? Why? If it's easy enough--quite easy, in fact--to do a little testing and find out what the actual optimal angle and actual optimal shape for your car are, why on earth wouldn't you do that instead of just guessing?
I don't want to put words in Julian's mouth, but as far as I understand, that's what he's arguing. He's posted extensively on testing methods, click on his username which will take you to his page, and then for "other posts" and "threads started by."
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
Isaac Zachary (07-25-2021)
