Thread: Thank you
Old 07-26-2021, 11:54 AM   #66 (permalink)
freebeard
but now I can't explain the gap between a mock-up and a template.
If you can't explain the gap between blindly following a template, and developing an optimal shape through test and development, then I can't help you.
But you can dodge the question. I can't explain your conceptual leap from no-template to mock-up.
We're back to using 'rule of thumb' instead of 'first approximation'? I don't have any more success than you do.
Think of it as more a guideline than a rule of the sea (Prts f th Crbbn). The spirit, if not the letter of the 'guideline' is that to get a smooth flow off the tail you need a clean stagnation.
