Thread: Thank you
Old 07-26-2021, 02:06 PM   #68 (permalink)
jjackstone
I haven't posted in a long time mainly due to the battle between Aerohead and JulianEdgar. Pretty much even quit looking at the aerodynamics section for the same reason. I didn't read all of this thread because it got boring after a couple pages and worse after that. Just a couple things I'd like to say and the I'll bow out again.
Mr. Edgar was writing about posting facts in there somewhere. I suggest that the facts should be posted with all references and the references qualifications if not already being done.
The other thing is, instead of arguing back and forth over who is correct, find someone to sponsor a contest between the two men and get each one of them an identical vehicle to modify. Then find a neutral party to test which vehicle has the lowest drag and is still roadable. The one with the lowest drag wins. End of battle. Elvis is leaving the building.
JJ
The Following User Says Thank You to jjackstone For This Useful Post:
Isaac Zachary (07-26-2021)
