Well, for starters the hitch on the tow car is a piece of flat steel so you can probably flex it by jumping on it and the U for clearing the bumper would make the flex worse, particularly left or right. It's probably a 1500 lb max load hitch.
It only takes about 25 lbs side force on the rear corner to loose control on the freeway and the towed car can probably generate more than that oscillating out of sync. So while you weren't going fast, all that mismatch car movement through the hitch was loading and unloading the rear tires. Another 10- 15 lbs air pressure might help in the rears.
The towed car portion looks ok.
